EigenFrequency with assembly form and roller bondary condition
I'm trying to do an eigenfrequency computation with a model of 4 solids connected together with "identity pair" as roller or fixed.
Basically one plate supported with 2 rubbers on one beam. Both rubbers ares clamped to the beam. One rubber is clamped to the plate, the other one has a roller pair condition.
The static analysis works well. I put a lateral load on the plate to create shear in rubber. As expected, the fully clamped rubber is subjected to shear stress, and the other no.
But I tried to run and eigenfrequency analysis with the same model. It runs, but the corresponding mode does not appears, I have only mode inside rubber, as the roller identity pair was not working for eigenfrequency problem ...
I attached my file if you want to give a look.
thanks in advance for your help
Martin
0 Replies Last Post 2017年5月5日 GMT+8 04:44
Hello Martin Pilon
