Rookie question: Calculation of eigenmodes
Posted 2011年2月24日 GMT+8 22:58 0 Replies
first of all sorry for my probably quite easy question, but I'm just started to used Comsol and I'm not able to solve my problem with the help of the documentation and hints found in the net.
Just for getting used of using Comsol I want to calculate the eigenmode of dylinderical wire. For it I choose in the RF module -> Electromagnetic Waves -> Eigenfrequency analysis, as Geometry I choose a block (dimension 1e-5, 1e-6,1e-6) with a cylinder (oriented in x-direction, length 1e-5 radius 1e-7) in the center. The dielectric properties of the cylinder are given by 1-omegap^2/omega^2 with omegap=1.4e16 and omega=2*pi*3e8/lambd0_rfw (all defined in Options->Expressions->Scalar Expressions). In Solver Parameter -> Eigenfrequency-> Eigenfrequency I have choosen Eigenvalue linearizion point as 0.5+omegap. If I now try to solve the model I received the message
Error: 7248
Undefined value found.
Exception:
com.femlab.jni.FlNativeException: Undefined value found Solvermodel
Stack trace:
at solvermodel.cpp, row 1837, (Undefined value found in the stiffness matrix.
There are 20 equations giving NaN/Inf in the matrix rows for the variable tExEyEz10
at coordinates: (5e-06,-8.50756e-08,-5.17434e-08), (5e-06,-5.17422e-08,-8.50767e-08), (5e-06,5.17434e-08,-8.50756e-08), (5e-06,8.50767e-08,-5.17422e-08), (5e-06,5.17434e-08,8.50756e-08), ...
There are 4 equations giving NaN/Inf in the matrix rows for the variable tExEyEz20
at coordinates: (5e-06,5.90095e-13,-5.17428e-08), (5e-06,5.90095e-13,5.17428e-08), (-5e-06,5.90095e-13,5.17428e-08), (-5e-06,5.90095e-13,-5.17428e-08), ...
There are 4 equations giving NaN/Inf in the matrix rows for the variable tExEyEz21
and similarly for the degrees of freedom, NaN/Inf in the matrix columns
at com.femlab.solver.FlSolver.femEig(Native Method)
at com.femlab.solver.FemEig.run(Unknown Source)
at com.femlab.server.FlRunner.run(Unknown Source)
at com.femlab.util.i.run(Unknown Source)
at com.femlab.util.aa.run(Unknown Source)
I would be very thankful for any hint,
Frank
Hello Frank Meyer
