Eigenfrequency of statically deflected clamped-clamped beam
Dear All,
Could someone share detailed procedure as to how to find eigenfrequency of statically deflected clamped-clamped beam? This occurs in modeling of resonant beam pressure sensor.
Ashwin Simha.
1 Reply Last Post 2011年2月25日 GMT-5 14:46
Posted: 1 decade ago 2011年2月25日 GMT-5 14:46
if it's the stressed eigenfrequencies you are looking for, you need to load the beam, perform a stationary analysis, then store the solution, and use the stored solution as starting point for the eigenfrequency analysis.
You set this up in the solver sequence
Hi if it's the stressed eigenfrequencies you are looking for, you need to load the beam, perform a stationary analysis, then store the solution, and use the stored solution as starting point for the eigenfrequency analysis. You set this up in the solver sequence -- Good luck Ivar
