Is it possible to use several model objects in the Matlab workspace?
did somebody already use several Comsol 4.1 model objects in the Matlab Workspace? (I do not want to
add model objects to a parent model object.)
In Comsol 3.5a I could save all my resulting fem structures (from a batch simulation) in a Matlab structure.
dat.fems{1,1} = fem1
dat.fems{1,2} = fem2
If I try to work with several Comsol 4.1 model objects, I get the error message attached below. Do I have to somehow trigger/update the "ModelUtil" or the "com.comsol.model.clientserver" if i want to change the current model ?
Here is an example workflow:
- create modelA and save it in the Matlab workspace as dat.modelA
- create modelB and save it in the Matlab workspace as dat.modelB
- try to save dat.modelA with dat.modelA.save('test.mph')
=> error:
??? Java exception occurred:
Exception:
org.eclipse.net4j.util.transaction.TransactionException: java.lang.NullPointerException
(rethrown as com.comsol.util.exceptions.FlException)
Error during client transaction
Stack trace:
at org.eclipse.emf.internal.cdo.transaction.CDOTransactionImpl.commit(CDOTransactionImpl.java:642)
at org.eclipse.emf.internal.cdo.transaction.CDOTransactionImpl.commit(CDOTransactionImpl.java:653)
at com.comsol.model.clientserver.ClientManagerImpl.commit(Unknown Source)
at com.comsol.model.clientserver.ClientManagerImpl.a(Unknown Source)
at com.comsol.model.clientserver.ClientManagerImpl.runServerJob(Unknown Source)
at com.comsol.model.impl.SolverSequenceImpl.getSize(Unknown Source)
Caused by: java.lang.NullPointerException
at org.eclipse.emf.internal.cdo.util.FSMUtil.adapt(FSMUtil.java:119)
at org.eclipse.emf.cdo.eresource.impl.CDOResourceImpl.getURIFragment(CDOResourceImpl.java:571)
at org.eclipse.emf.ecore.util.EcoreUtil.getURI(EcoreUtil.java:2899)
at org.eclipse.emf.internal.cdo.view.CDOViewImpl.provideCDOID(CDOViewImpl.java:933)
at org.eclipse.emf.cdo.spi.common.revision.AbstractCDORevision.writeValues(AbstractCDORevision.java:653)
at org.eclipse.emf.cdo.spi.common.revision.AbstractCDORevision.write(AbstractCDORevision.java:168)
at org.eclipse.emf.cdo.internal.common.io.CDODataOutputImpl.writeCDORevision(CDODataOutputImpl.java:160)
at
org.eclipse.emf.internal.cdo.net4j.protocol.CommitTransactionRequest.writeRevisions(CommitTransactionRequest.java:313)
at
org.eclipse.emf.internal.cdo.net4j.protocol.CommitTransactionRequest.requestingCommit(CommitTransactionRequest.java:215)
at org.eclipse.emf.internal.cdo.net4j.protocol.CommitTransactionRequest.requesting(CommitTransactionRequest.java:163)
at org.eclipse.emf.internal.cdo.net4j.protocol.CommitTransactionRequest.requesting(CommitTransactionRequest.java:103)
at org.eclipse.net4j.signal.RequestWithMonitoring.requesting(RequestWithMonitoring.java:163)
at org.eclipse.net4j.signal.RequestWithConfirmation.doExtendedOutput(RequestWithConfirmation.java:117)
at org.eclipse.net4j.signal.Signal.doOutput(Signal.java:281)
at org.eclipse.net4j.signal.RequestWithConfirmation.doExecute(RequestWithConfirmation.java:102)
at org.eclipse.net4j.signal.RequestWithMonitoring.doExecute(RequestWithMonitoring.java:233)
at org.eclipse.net4j.signal.SignalActor.execute(SignalActor.java:66)
at org.eclipse.net4j.signal.Signal.runSync(Signal.java:238)
at org.eclipse.net4j.signal.SignalProtocol.startSignal(SignalProtocol.java:427)
at org.eclipse.net4j.signal.RequestWithConfirmation.doSend(RequestWithConfirmation.java:87)
at org.eclipse.net4j.signal.RequestWithConfirmation.send(RequestWithConfirmation.java:73)
at org.eclipse.net4j.signal.RequestWithMonitoring.send(RequestWithMonitoring.java:108)
at org.eclipse.emf.internal.cdo.net4j.protocol.CDOClientProtocol.send(CDOClientProtocol.java:302)
at org.eclipse.emf.internal.cdo.net4j.protocol.CDOClientProtocol.commitTransaction(CDOClientProtocol.java:220)
at
org.eclipse.emf.internal.cdo.transaction.CDOSingleTransactionStrategyImpl.commit(CDOSingleTransactionStrategyImpl.java:58)
at org.eclipse.emf.internal.cdo.transaction.CDOTransactionImpl.commit(CDOTransactionImpl.java:626)
... 5 more
3 Replies Last Post 2012年9月29日 GMT-4 14:09
Posted: 1 decade ago 2011年3月12日 GMT-5 09:05
Using random model tags solved this issue.
Posted: 1 decade ago 2012年6月4日 GMT-4 12:35
I have also received the same error messages (in Comsol 4.2a) when trying to access the mesh information of a model already in the workspace. Any fixes for this?
I would use
mesh = mpxmeshinfo(model); and the link would crash
It is not always this command, but this is the most common
I have also received the same error messages (in Comsol 4.2a) when trying to access the mesh information of a model already in the workspace. Any fixes for this? I would use mesh = mpxmeshinfo(model); and the link would crash It is not always this command, but this is the most common
Posted: 1 decade ago 2012年9月29日 GMT-4 14:09
Could you explain that point ?
Thank you in advance.
L. Queval
Could you explain that point ? Thank you in advance. -- L. Queval
