Using 'if' statement with two conditions
Posted 2011年3月11日 GMT+8 18:59 7 Replies
I want to use and if statement in COMSOL but I need it to have two conditions.
I want to calculate the value of the x coordinate when y = 0 and T=300.
Something like:
if(y ==0 and T == 300, xi == x)
Would the AND logical operator (&&) work instead of the and in my above statement?
No matter what I try I get errors.
Someone mentioned in a previous post that my if statement must not contain discontinuities and that they can be avoided by combining the if and sens operators, I don't understand how to do this though.
I would really appreciate some help with this problem!
-Adam.
the discontinuity issue is when you use such Dirac functions for the physics, then the solver might "jump over them"
perhaps if you use more (), or try a boolean
(x==0)*(T==300)*YourValue
Thanks for the quick reply.
I understand what you are saying.
However I wish to assign the variable xi to the value of x when T=300 and y=0.
So that if both T=300 and y=0 are true (then equal to one) then whatever the x coordinate at the point is gets assigned to xi.
If I use the expression you suggested then xi comes back with a value of 0.
I am trying to use an if statement to get the value I want but keep getting a value of 0 for xi:
if(T==300 && y == 0,xi == x)
I hope I have made my problem clear!
I would really appreciate some help!
-Adam
then what about:
Your_value = (y==0)*(T==300)*(My_New_Value - Some_other_value) + Some_other_value
there are two places whree aou can test out formulas:
- the parameter line that calcualtes out your value (and translates the units)
- the analytical function, whcih allows you quickly to plot a function. I mostly write my complex fomulas as functions, as then I can plot them easily to check how they look, its so easy to forget a sign, or an offset. Alwaysmverify and validate your work,in steps it's easier ;)
I can easily plot the function f=(x<= 5).
But how to plot a function f=(x<=5,y<=5) in a 2D plan.
Cheers,
Dao
have you tried the filter and (x<5)*(y>2) condition, or whatever Boolena condition you need ?
Suggested Content
- BLOG How to Use State Variables in COMSOL Multiphysics®
- KNOWLEDGE BASE How do I solve a PDE with space derivatives of order higher than two?
- KNOWLEDGE BASE Solving time dependent models with inconsistent initial values
- BLOG Solutions as Starting Point Values with LiveLink™ for MATLAB®
- FORUM If Statement
