error message: "Made 5 attempts creating a temp. file. Giving up!"
Posted 2011年3月15日 GMT+8 16:01 Version 4.1 0 Replies
when I run a Comsol model from a Matlab model script on my local machine, it runs without a problem.
At the end the scripts generates some Comsol data sets and exports results along some 3D cut lines.
These files are created during a script run on my local machine without problems as well..
BUT: When I run the same script on my local machine, when it is connected to a comsol server, the exported result files will not be written.
The error message attached below appears in the Matlab command prompt.
To me it first seemed to be a read/write permission error. So I changed the directories on the Comsol server machine so that I have now write access as well.
I also tried using the -tmpdir swith with the comsolserver command and redirected Comsol's temporary files into a directory, where I have write access as well.
There are some temporary files created during the model run in this directory. So the redirection seems to work.
But still Comsol complains, that temporary files cannot be written.
Did anyone experience the same problem and has found a solution to this?
Is it a Java issue on the server machine?
Thanks a lot,
Juergen
??? Java exception occurred:
Exception:
java.lang.RuntimeException: Made 5 attempts creating a temp. file. Giving up!
(rethrown as com.comsol.util.exceptions.FlException)
Stack trace:
at com.comsol.systemutils.SystemUtil.a(Unknown Source)
at com.comsol.systemutils.SystemUtil.createTempFile(Unknown Source)
at com.comsol.server.internal.f.createFile(Unknown Source)
at com.comsol.model.util.ModelUtil.createFile(Unknown Source)
at com.comsol.post.a.j.a(Unknown Source)
at com.comsol.post.a.h.execute(Unknown Source)
at com.comsol.model.impl.ExportFeatureImpl.n(Unknown Source)
at com.comsol.model.impl.ExportFeatureImpl.serverRun(Unknown Source)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at com.comsol.clientserver.impl.JobImpl.run(Unknown Source)
at com.comsol.server.internal.b.a(Unknown Source)
at com.comsol.server.internal.b$h.a(Unknown Source)
at com.comsol.server.internal.b$h$a.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Error in ==> script_run_automatic at 662
model.result.export('data1').run;
Hello Juergen Hansmann
