"ALE" VS "Spatial Frame" equivalent for this problem?
Posted 2011年3月15日 GMT+8 22:12 Structural Mechanics Version 4.1 1 Reply
Hi!
I notice that there are many interesting discussions about moving mesh.
Now I have a simple question about ALE and different frames in Comsol 4.1.
Say that want to solve a Darcy's law equation based on the deformed structure mesh. It's similar to solve a heat problem based on the deformed structure.
Two ways to solve this in V4.1.
1. Checked the option "displacements control the spatial frame" (it's checked by default). Solve the solid phase in the material frame, and select the frame type of Darcy's law module to "Spatial frame".
2. Use ALE. Unchecked "displacements control the spatial frame" in solid structure module. Add moving mesh module. Selected Darcy's law frame type to Spatial frame (I was expecting "ALE frame" as version 3.5a, but the name is still "Spatial frame"), ALE displacement set to the displacement of the solid phase.
I tested above two method, they give almost identical results.
But theoretically they should be equivalent?
In this case, they we don't even need ALE for this kind of problem any more? Then where is ALE needed? For extremely large deformation where remesh is needed?
Thanks a lot.
XLi
Thanks a lot.
XLi
1 Reply Last Post 2011年3月15日 GMT+8 23:23
