Postprocessing: Skewed scales on 2D plots
Posted 2011年3月16日 GMT+8 00:12 Fluid & Heat, Results & Visualization Version 4.0a, Version 4.1 3 Replies
I have 2-D porous media model that I use to run flow and transport simulations (Laminar Flow and Transport of Diluted Species modules, respectively). The simulations works very well. However, the problem is in the post-processing.
The domain is a rectangle: 7.4 cm long by 1.5 cm high. Most of the time when I view 2D plots (surface plots), the spacing in the x and y directions are equal (i.e. the scales are the same so the domain looks like the rectangle that it is). But, other times, the scales are skewed such that it plots my domain into a square! This problem comes up without any reason as far as I can tell. I will be using the same model and it will plot things with the correct scales, and then one time when I re-open the model and click on the 2D plot results, the skewed plot shows up.
I don't know why this happens and I can't seem to go back to have equal-scaled plots when the skewed results come up.
Any help would be much appreciated!
Thanks.
Thanks.
3 Replies Last Post 2011年3月16日 GMT+8 00:29
