Error "Multiple moving frame specifications on the same selection" when trying to use Moving Mesh
Dear all, I am trying to simulate a very simple spherical indentation in material and because the difficulties to get a stable convergence I 'd like to implement a moving Mesh in my Project. Nevertheless I receive everytime the error: Multiple moving frame specifications on the same selection. - Selection: Domain 1 Has someone an idea of what does it means an d how can I get rid of it?
Thanks a lot for your help
Regards
G.M.
3 Replies Last Post 2017年12月20日 GMT-5 10:37
Posted: 7 years ago 2017年12月20日 GMT-5 04:37
Hi Gabriele,
The most common reason for this error message would be that you have assigned a moving mesh and Solid Mechanics to the same domain. That cannot be done, since it would imply a conflict as Solid Mechanics itself is defining the deformation of the frame.
Henrik
Henrik Sönnerlind
COMSOL
Hi Gabriele, The most common reason for this error message would be that you have assigned a moving mesh and Solid Mechanics to the same domain. That cannot be done, since it would imply a conflict as Solid Mechanics itself is defining the deformation of the frame. Regards, Henrik
Posted: 7 years ago 2017年12月20日 GMT-5 05:34
Hi Henrik, that's exactly what I did and now I understand the problem. Thanks. Unfortunately in the user's manual the incompatibility of these two options is not so well highlighted .
Regards
Gabriele
Hi Gabriele,
Henrik
Hi Henrik, that's exactly what I did and now I understand the problem. Thanks. Unfortunately in the user's manual the incompatibility of these two options is not so well highlighted . Regards Gabriele >>Hi Gabriele, > >The most common reason for this error message would be that you have assigned a moving mesh and Solid Mechanics to the same domain. That cannot be done, since it would imply a conflict as Solid Mechanics itself is defining the deformation of the frame. > >Regards, > > Henrik
Posted: 7 years ago 2017年12月20日 GMT-5 10:37
Hi Gabriele,
Thanks for the comment about the documentation. We will improve it for the next release.
Henrik
Henrik Sönnerlind
COMSOL
Hi Gabriele, Thanks for the comment about the documentation. We will improve it for the next release. Regards, Henrik
