2011年3月31日 GMT+8 20:27
I'm dealing with the same issue, though I just make sure the air large enough so the zero flux boundaries dont effect my electric field too much.
2011年4月2日 GMT+8 00:22
In the RF module you should consider using a PML domain surrounding your air domain. On the outside of the PML domain, you can add a scattering boundary condition. This will help to reduce your total domain size for solving in 3d.
2011年4月4日 GMT+8 17:16
Thanks for the responses,
When i use zero charge as a boundary things look completely wrong in the solution - the voltage is spread across the whole space, instead of confined to the metal parts, the electric field doesn't make much sense either.
When I use ground i get a much more well-behaved solution but i wonder if it is right - surrounding my object with ground is like putting it in a faraday cage no? Where no fields can exist.
I would love to have a clear instruction on the best practice here.
2011年4月4日 GMT+8 18:11
as soon as you have electric charge inside the cage, you have fields of course. Only fields from outside sources don't enter the cage.
You will need to make the cage big enough. One way to verify is to check whether the fields within the range you are interested in are still influenced by the size of the cage.
You start with a certain size, run the model, change the size and check the effect on the results. If your desired level of precision is reached you should be fine.
A second option can be to calculate the boundary potential from an analytical approximation. E.g. if your assembly looks like a point charge from the distance you can try to apply the potential distribution of the point charge to the boundary.
This approach works fine for me in a magnetostatic case where I apply the analytical magnetic dipole field to the boundary. This allowed to decrease the size of the container very significantly.
Regards
Edgar
Regards
Edgar
2011年4月4日 GMT+8 19:32
Thankyou Edgar,
This is very helpful.
Just to clarify, it is okay for me to use the ground boundary condition (assuming the size of the container no longer affects my solution to with tolerance)
Thanks again,
Kind regards,
Dom.
Thankyou Edgar,
Thanks again,
Kind regards,
Dom.
2011年4月4日 GMT+8 20:23
It doesn't really matter what you use provided you verify that the boundary doesn't significantly influence your region of interest.
Floating might be better than ground, because it allows some adjustment of the boundary to the potentials the model generates inside.
