minimum between two variables
Posted 2017年12月22日 GMT+8 00:00 Fluid & Heat, Heat Transfer, Porous Media Flow Version 5.3 5 Replies
Hi, I'm performing a simulation using the Heat Transfer in Fluids and Laminar Fluid Flow modules. In my problem, the viscosity is governed by two different equations. I need to impose that the dynamic viscosity (n) to be used (imposed as user defined in the Laminar Flow under Fluid Properties) is the minimum value between the two viscosities calculated according to the two different equations, something like:
n=min(nT,nY)
I wonder if this is the correct way to ask Comsol to calculate the minimum between two variables or not.
Thank you, all the best, Valentina
Good guess! See Reference Manual for COMSOL Multiphysics, version 5.3a, page 244. All documentation is accessible through File > Help > Documentation.
-------------------Jeff Hiller
Hi, I checked on the documentation for Comsol 5.3, but I don't understand if the expression MIN can be used in my case, since the arguments are variables. I read that there is also ATTIMEMIN, but I think is not useful for my case, since I need to define the viscosity imposed as user defined in the Laminar Flow under Fluid Properties as the minimum between the two variables. It's not a result evaluation. I tried to run the code using n=min(nT,nY), but the simulation gives error after a while during the calculations.
Thanks, Valentina
Hello Valentina,
Min should work even for variables, so I suspect the source of your problem is somewhere else. I recommend you contact COMSOL's support team at support@comsol.com .
Thank you so much, all the best, Vale
Hi, I got this error when I try to run the model:
Velocity u, Pressure p Attempt to evaluate negative power of zero. - Function: ^ Failed to evaluate temporary symbolic derivative variable. - Variable: epII@VDN$mod.ux - Defined as: (0.5((0.5((((2(((ep12^2)+(ep13^2))+(ep23^2)))+(ep11^2))+(ep22^2))+(ep33^2)))^(-0.5)))(0.5(2ep11)) Failed to evaluate temporary symbolic derivative variable. - Variable: nb@VDN$mod.ux - Defined as: (((0.5((0.5((((2(((ep12^2)+(ep13^2))+(ep23^2)))+(ep11^2))+(ep22^2))+(ep33^2)))^(-0.5)))(0.5(2ep11)))1.4142135623730951)((-(c0-(((fcrho)g)z)))/((epII1.4142135623730951)^2)) Failed to evaluate temporary symbolic derivative variable. - Variable: n@VDN$mod.ux - Defined as: (nT>nb)((((0.5((0.5((((2(((ep12^2)+(ep13^2))+(ep23^2)))+(ep11^2))+(ep22^2))+(ep33^2)))^(-0.5)))(0.5(2ep11)))1.4142135623730951)((-(c0-(((fcrho)g)z)))/((epII1.4142135623730951)^2))) Failed to evaluate temporary symbolic derivative variable. - Variable: mod.spf.mu@VDN$mod.ux - Defined as: (nT>nb)((((0.5((0.5((((2(((ep12^2)+(ep13^2))+(ep23^2)))+(ep11^2))+(ep22^2))+(ep33^2)))^(-0.5)))(0.5(2ep11)))1.4142135623730951)((-(c0-(((fcrho)g)z)))/((epII1.4142135623730951)^2))) Failed to evaluate temporary symbolic derivative variable. - Variable: mod.spf.mu_eff@VDN$mod.ux - Defined as: (nT>nb)((((0.5((0.5((((2(((ep12^2)+(ep13^2))+(ep23^2)))+(ep11^2))+(ep22^2))+(ep33^2)))^(-0.5)))(0.5(2ep11)))1.4142135623730951)((-(c0-(((fcrho)g)z)))/((epII1.4142135623730951)^2))) Failed to evaluate temporary symbolic derivative variable. - Variable: mod.spf.K_stress_tensorxz@VDN$mod.ux - Defined as: (mod.uz+mod.wx)((nT>nb)((((0.5((0.5((((2(((ep12^2)+(ep13^2))+(ep23^2)))+(ep11^2))+(ep22^2))+(ep33^2)))^(-0.5)))(0.5(2ep11)))1.4142135623730951)((-(c0-(((fcrho)g)z)))/((epII1.4142135623730951)^2)))) Failed to evaluate expression. - Expression: dvol(-((mod.uz+mod.wx)((nT>nb)((((0.5((0.5((((2(((ep12^2)+(ep13^2))+(ep23^2)))+(ep11^2))+(ep22^2))+(ep33^2)))^(-0.5)))(0.5(2ep11)))1.4142135623730951)((-(c0-(((fcrho)g)z)))/((epII1.4142135623730951)^2)))))) Failed to evaluate Jacobian of expression. - Expression: dvol(-mod.spf.K_stress_tensorxz) Failed to evaluate Jacobian of expression. - Expression: ((mod.p-mod.spf.K_stress_tensorxx)test(mod.ux)-mod.spf.K_stress_tensorxytest(mod.uy)-mod.spf.K_stress_tensorxztest(mod.uz)-mod.spf.K_stress_tensoryxtest(mod.vx)+(mod.p-mod.spf.K_stress_tensoryy)test(mod.vy)-mod.spf.K_stress_tensoryztest(mod.vz)-mod.spf.K_stress_tensorzxtest(mod.wx)-mod.spf.K_stress_tensorzytest(mod.wy)+(mod.p-mod.spf.K_stress_tensorzz)test(mod.wz))*(dvol)
what can be the issue?
thank you, all the best, V.
Suggested Content
- FORUM How to enforce minimum gap between two vibrating structures- FSI
- BLOG Maximizing Eigenfrequencies with Shape and Topology Optimization
- KNOWLEDGE BASE Wrong Number of DOFs in Linearization Point
- BLOG How to Compute Distances Between Objects in COMSOL Multiphysics®
