[comsol 3.5a]double loop prametric analysis
Posted 2009年11月14日 GMT+8 02:06 1 Reply
Hello to all
I am modeling with 3 module, structural, ALE and Electrostatic in 2D dimensions. I have two blocks, a fixed plate and a mass that are parallel each other. Using a parametric analysis i move the mass and in relationship with the movement i calculate the capacity variation between mass and plate.
Now i would make the same analysis that i explained up, but in addition i would change the orientation of the fixed plate, making rotation around its centre of mass. Is it possible to develop a model that make this analysis in automatic way?
This program should at first rotate the fixed plate of 3° ,second calculate the capacity variation in relationship with the mass movement, when it ends this process it should start again with another angle. I would avoid to change the geometry every time if is possible.
Thank you in advance
bye
Luca
bye
Luca
1 Reply Last Post 2009年11月14日 GMT+8 17:41
