Laminar flow with periodic inlet
Posted 2011年4月15日 GMT+8 14:07 Fluid & Heat, Geometry, Studies & Solvers Version 4.1 1 Reply
I redraw the graph which is simpler, domain 1 is fluid domain, others 2-5 are used later for plane strain.
my boundary conditions are (because it is the valve in our body, so the entrance velocity is periodic)
1. entrance
assume a fully developed parabolic axial velocity u(0,y,t) and v (0, y, t) at the tube entrance, the axial velocity is assumed to be periodic
u(0,y,t)=Um(r(0,t)-y)(r(0,t)+y)
UM=U_max*sin(2*pi*t/Tc) (n-1)Tc<t<(n-0.5)Tc Tc is the period=3s
=0 (n-0.5)Tc<t<n*Tc
u_max is the maximum axial centerline velocity and Tc is the time between opening and closing of the leaflet(domain 3)
2. Exit prescribed pressure condition Pd=1000pa
3. Internal boundary of the tube wall
assumed to be the same as the rate of the displacement of internal tube wall in the respective directions.
For here I just assume they are no slip wall to see if the model can work or not.
4. centerline
Symmetric boundary conditions are assumed.
These are the right conditions that after I discussed with my professor. But I really don't know how to put periodic boundary conditions in the model, and I am not sure other boundaries are right or not. so would you please check it for me?
how can I define like 0<t<1.5, UM=U_max*sin(2*pi*t/Tc), when 1.5<t<3, UM=0, should I use the wave function?
I will run this model first and then add the moving mesh in 2-5
Thank you for all your help to help me and walk together with me on this difficult comsol road!
Give my bigggest thanks first!
1. entrance
=0 (n-0.5)Tc<t<n*Tc
4. centerline
1 Reply Last Post 2011年4月15日 GMT+8 15:53
