Spherical shell eigenfrequency analysis with static internal pressure
Posted 2011年4月16日 GMT+8 06:28 Acoustics & Vibrations, Modeling Tools & Definitions, Parameters, Variables, & Functions, Structural Mechanics Version 4.1 4 Replies
My student and I are trying set up a model to investigate how the vibration response of a fluid-filled spherical shell changes with the static fluid pressure. We have a corresponding lab experiment with a 15 cm diameter aluminum shell filled with water that shows a 10 kHz peak shifting about 2 Hz for every 10 psi increase in water pressure.
Changing the fluid pressure inside the shell in COMSOL has no apparent effect on the eigenfrequencies. Although this is a case of prestressing the structure, the displacement is tiny compare to other models with a static load that I've read about in this forum. I'm not sure that the Buckling Analysis procedure applies here. We've been using acoustic-structure interaction in the Acoustics module, but we do not currently have the Structural Mechanics module.
In order to follow the procedure of solving for stress/strain due to the static pressure, then using that as an initial condition for the eigenfrequency analysis, is it necessary to have the Structural Mechanics module? Can this be done within the Acoustics module (or the basic COMSOL package)?
Any insight will be greatly appreciated.
Andy
Andy
4 Replies Last Post 2011年4月19日 GMT+8 02:58
