5.3a parametric sweep
Posted 2018年3月14日 GMT+8 08:00 Heat Transfer & Phase Change Version 5.3a 1 Reply
Hello, I am performing a parametric sweep study, however comsol gives the error message "Parameters: "thick","0.01" The following feature has encountered a problem: - Feature: Parametric 1 (sol1/s1/p1) - Feature: Stationary Solver 1 (sol1/s1) Parameter names must not be empty."
I am amazed something that didn't happen previously is causing an error in the latest version. I also found a similar error for multiphysics - Nonisothermal flow coupling where it causes an error with "reference density" not defined. I would like to know if this is an issue with the version, or something has changed and if I need to change something. I haven't faced these issues previously.
Thanks -Sai
