How to export a deformed shell?
Is there any way to export a bent shell from a structural mechanics simulation? I really need to know how I can do so? Remesh deformed configuration just works for solid and not the shell. Do you have any idea?
Kind regards
2 Replies Last Post 2018年5月4日 GMT+8 05:42
Posted: 8 years ago 2018年5月4日 GMT+8 05:17
Updated: 8 years ago 2018年5月4日 GMT+8 05:18
Shaghayegh-
The remesh deformed configuration option only works on a volumetric mesh so it won't work on the 3D surface mesh (as you've discovered). A workaround here would be to export a 3D plot (with deformation) of your shell analysis as an STL file.
This technique is explained here by Temesgen Kindo (see end of his blog):
www.comsol.com/blogs/how-to-reuse-a-deformed-shape-as-a-geometry-input/
I've used this technique. It works great.
Have fun!
Josh Thomas
AltaSim Technologies
Shaghayegh- The remesh deformed configuration option only works on a volumetric mesh so it won't work on the 3D surface mesh (as you've discovered). A workaround here would be to export a 3D plot (with deformation) of your shell analysis as an STL file. This technique is explained here by Temesgen Kindo (see end of his blog): www.comsol.com/blogs/how-to-reuse-a-deformed-shape-as-a-geometry-input/ I've used this technique. It works great. Have fun!
Posted: 8 years ago 2018年5月4日 GMT+8 05:42
Dear Josh,
Thanks a lot! this is exactly what I want! I greatly appreciate your help.
Best wishes, Shaghayegh
Dear Josh, Thanks a lot! this is exactly what I want! I greatly appreciate your help. Best wishes, Shaghayegh
