Conjugate Heat Transfer for Turbulent Flow problem
I have seen that you have helped a lot of people many times about different types of problems in COMSOL, that's why I'm contacting you.
I study the aerothermal effects of a CubeSat which comes back to earth. First, I made lot of assumptions to simplify my model.
I began to learn COMSOL few weeks ago. First I made a model with laminar flow, I imposed a velocity for the inlet and open boundaries for the outlet. It worked.
Them, I add conjugate heat transfert for laminar and it worked too.
But when I study the turbulent flow I don't understand why it doesn't work ...
I have the message below :
Failed to find a solution. Segregated Step 2 Singular matrix.
There are 409 void equations (empty rows in matrix) for the variable comp1.T. at coordinates: (0.221669,0.25,0.551122), (0.227749,0.25,0.542537), (0.225979,0.241028,0.546981), (0.220487,0.240859,0.555651), (0.225796,0.258812,0.547148), ... There are 409 void equations (empty rows in matrix) for the variable comp1.nitf1.TWall. at coordinates: (0.233762,0.240739,0.538702), (0.234585,0.25,0.535845), (0.227749,0.25,0.542537), (0.24I have seen that you have helped a lot of people many times about different types of problems in COMSOL, that's why I'm contacting you.
There are 409 void equations (empty rows in matrix) for the variable comp1.T. at coordinates: (0.221669,0.25,0.551122), (0.227749,0.25,0.542537), (0.225979,0.241028,0.546981), (0.220487,0.240859,0.555651), (0.225796,0.258812,0.547148), ... There are 409 void equations (empty rows in matrix) for the variable comp1.nitf1.TWall. at coordinates: (0.233762,0.240739,0.538702), (0.234585,0.25,0.535845), (0.227749,0.25,0.542537), (0.242123,0.25,0.531499), (0.25,0.25,0.53), ... In Segregated Step 2: Returned solution is not converged.
Please can you help me.
You will find my model attached.2123,0.25,0.531499), (0.25,0.25,0.53), ... In Segregated Step 2: Returned solution is not converged.
0 Replies Last Post 2018年5月21日 GMT+8 11:47
Hello Olivier Lambert
