How to derive capacitance matrix
I have a four core cable and I want to get the capacitance matrix over frequency.
I set the common screen to be ground and set the four cores to be different terminal, list them 1 to 4. and set them to be voltage terminal type with voltage of 1V.
I want to use parameter sweep of PortName. However, I am confused about how to define PortName in global parameter definition. I can give a name of PortName, but then what is the expression? I now set it to be PortName again and I get yellow warning. Simulation seems to run but I get nothing in result.
Another question is how can I get the result in a frequency range?
2 Replies Last Post 2018年7月3日 GMT-4 21:20
Nirmal Paudel Tribhuvan University/Electrical Engineering
Posted: 7 years ago 2018年6月27日 GMT-4 08:57
Updated: 7 years ago 2018年6月27日 GMT-4 08:57
The following blog post might be helpful here.
https://www.comsol.com/blogs/how-to-calculate-a-capacitance-matrix-in-comsol-multiphysics/
See also this application:
https://www.comsol.com/model/touchscreen-simulator-30841
Best Regards, Nirmal Paudel
Hi, The following blog post might be helpful here. https://www.comsol.com/blogs/how-to-calculate-a-capacitance-matrix-in-comsol-multiphysics/ See also this application: https://www.comsol.com/model/touchscreen-simulator-30841 Best Regards, Nirmal Paudel
Posted: 7 years ago 2018年7月3日 GMT-4 21:20
Thank you Nirmal
I solved the capacitance problem, but now I have difficulties in inductance. Can you help to take a look at my new post:https://www.comsol.com/forum/thread/181623/how-to-derive-inductance-of-the-3d-transmission-line-under-magnetic-field?last=2018-07-04T01:18:21Z
Thanks in advance.
Thank you Nirmal I solved the capacitance problem, but now I have difficulties in inductance. Can you help to take a look at my new post:https://www.comsol.com/forum/thread/181623/how-to-derive-inductance-of-the-3d-transmission-line-under-magnetic-field?last=2018-07-04T01:18:21Z Thanks in advance.
