Piezoelectric coupled with a electric circuit for vibration damping
Posted 2018年6月26日 GMT+8 08:20 Electromagnetics, Piezoelectric Devices, Structural & Acoustics Version 5.3 2 Replies
Hi, everyone! I am simulating the effect of a shunt circuit on the vibration of a piezoelectric device. Theoretically, with a shunt circuit connected (a resistor and a inductor in serie with the pzt), the vibration of the device will be further damped. However, when I connect a shunt circuit to the two electrodes of the pzt, the vibration amplitude is unchanged. I think the circuit and the pzt is not coupled well and the circuit does not back-affect the pzt module.
The main boundary setup of my model are:
For the PZT module: 1. The PZT is attached to beam that is fixed at one end and a harmonic loading is applied on the other end; 2. the lower face of the PZT is grounded; the upper face is set as Terminal.
For the electric circuit module: 1. ground node is 0; 2. "External I vs.U" is added between 2 and 0 and is connected the Solid Mechanics module and the voltage is the Terminal on the upper face of the PZT. 3. a resistor node is added between 2 and 1; 4. a inductor is added between 1 and 0;
So the question is: 1. will the "electric circuit " module response back to the Solid Mechanics module? 2. will the "electric circuit" module consider the conservation of energy and thus can consume the mechanical energy in the form of joule heating? 3. any comment on this model and any suggestions?
Thank you in advance for any comment and help!!
José Emilio Traver
