2009年11月23日 GMT-5 19:32
An easy way would just be to define a subdomain integration coupling variable, name it "volume," and use 1 as your expression. Now your volume variable will contain the actual volume of that subdomain. I just tried this method for a simple rectangular geometry and it seems to work fine.
I should point out that I tried this with plane-strain mode, I'm not sure if you need to do anything differently for axisymmetric mode. But you can easily try it with simple geometry (that you know the answer to) and see if it works.
Good luck,
Mike
Good luck,
Mike
2009年11月27日 GMT-5 17:55
for axisymmetry you must use the "2*pi*r" with some care, it can be applied by a click for the BC (boundary conditions since 3.5) but must be applied by "hand" for boundary integration variables.
As suggested, by trying out on simple cases, and studying the units of COMSOL you can find easily the correct dimensions to apply (always check units 30 years later I start to understand that statement from my physics teacher ;)
COMSOL requires some "thinking" and pysics knowledge, but it has far more freedom than other "out-of the box" FEM programmes.
2009年12月18日 GMT-5 06:14
Thanks! Works great!
Johan
Johan
