Can I get the whole time solution if start from the stored solution and continue?
It is a transient problem.
I store the solution after it completes the first 2 second computatoin.
Then I decide to continue the computation for another 8 seconds using the stored solution as the initial values.
The question is whether I can get the whole 10 second solution in the file? For instance, if I want to plot the temperatue vs time from the very beginning to the 10th seconds, am I able to do that? Currently I can not figure out yet.
2 Replies Last Post 2011年5月14日 GMT+8 06:26
Posted: 1 decade ago 2011年5月14日 GMT+8 04:38
in the same model file I believe yes, but in two different data set, that may be accessed as two seqential subnoes to a results - plot node
Hi in the same model file I believe yes, but in two different data set, that may be accessed as two seqential subnoes to a results - plot node -- Good luck Ivar
Posted: 1 decade ago 2011年5月14日 GMT+8 06:26
Hi, that makes sense, thanks.
