How to model compression?
Posted 2011年5月24日 GMT+8 04:41 Structural Mechanics 3 Replies
Hi All,
The set up for the model is a thin wire entering a block of material. The wire is already inserted to a certain depth. I am trying to determine if a compressive force is applied to the top of the wire, at what depth the wire will no longer buckle. I keep getting an error when trying to run the Study which says: The mass matrix is zero. I am a novice with COMSOL and looking for any sort of suggestions or advice.
The COMSOL parameters are currently using a Solid Mechanics platform with a point load defined and a linear buckling step. The mesh was only applied to the wire.
Any suggestions?
Thank you!
Amanda
Any suggestions?
Thank you!
Amanda
3 Replies Last Post 2011年5月25日 GMT+8 22:55
