Near- to far-field tranform in Comsol v4.2
Dear all,
I read that the near- to far-field transform in Comsol v4.2 is now supporting media, which have a different refractive index than 1. Therefore, it seem to be possible now to calculate the scattering pattern of a particle embedded in for instance glass using the adapted Stratton-Chu formulas. Before it was only possible to calculate the far-field in free space. At least, this was stated in the manual of Comsol v4.0.
My question is the following:
Is it possible in Comsol v4.2 to calculate the far-field in the case of non-homogeneous media using the implemented far-field feature? Imagine for instance the excitation of a nano-particle sitting on a glass substrate by a plane wave. This is a very sophisticated situation, because the substrate breaks the symmetry of the system and the near-field can not just be propagated to the far-filed using the standard Green's function.
Thanks in advance.
Peter
1 Reply Last Post 2014年9月30日 GMT-4 08:51
Hello Peter Banzer
Posted: 1 decade ago 2014年9月30日 GMT-4 08:51
Hi Peter,
Have you got solution for your question?. I am also looking for same clarification. How to calculate the scattering in forward and backward direction by scatter on substrate?. If I draw one enclosed surface around the particle on substrate, I observed that it is split into two parts those can be assigned for two different Efar variables in V4.4. What modifications I have to do for scattering cross section calculation in media compared to the equation of free space?. Any suggestions would be appreciable.
Mahnedar
Hi Peter, Have you got solution for your question?. I am also looking for same clarification. How to calculate the scattering in forward and backward direction by scatter on substrate?. If I draw one enclosed surface around the particle on substrate, I observed that it is split into two parts those can be assigned for two different Efar variables in V4.4. What modifications I have to do for scattering cross section calculation in media compared to the equation of free space?. Any suggestions would be appreciable. Thanks Mahnedar
