Volume average - multiple evalutions without tedious work
Hello everyone, in my project i would like to obtain average values of magnetic fields over ~100 or so domains in my model. My question is as follows: is there any quick/not extremely tedious ways to obtain 100 evaluations (each evalutionis done in a different domain) into one table or exported file? As unexperienced Comsol user it seems that there must exist a way to do that without obnioxous amount of clicking.
I would be very greatful for suggestions/solutions. Sincerely, Peter
4 Replies Last Post 2018年9月26日 GMT-4 10:29
Posted: 6 years ago 2018年9月22日 GMT-4 03:59
Piotr,
this is something you typically do in a Comsol application, a model method or in a Matlab script.
Cheers Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Piotr, this is something you typically do in a Comsol application, a model method or in a Matlab script. Cheers Edgar
Posted: 6 years ago 2018年9月23日 GMT-4 06:11
Hi, Thank you very much for your response. Can you possibly specify how to write an application which evalute volume average of expression "mf.Bz" ,changing domain of evaluation from domain 1 to lets say 100?
I'm not familliar with application builder, and found it hard to find an example doing something simillar. Any help would be greatly appreciated.
Peter
Hi, Thank you very much for your response. Can you possibly specify how to write an application which evalute volume average of expression "mf.Bz" ,changing domain of evaluation from domain 1 to lets say 100? I'm not familliar with application builder, and found it hard to find an example doing something simillar. Any help would be greatly appreciated. Peter
Posted: 6 years ago 2018年9月23日 GMT-4 09:14
Peter,
you will not get around studying the application builder. I guess you will have to look into the definition of selections and component couplings. Make yourself familiar with the method-recording function. It allows to record all the clicking (and the API calls behind) you do to manually define the functionality you need. Then you can wrap that into some kind of loop to automate things for 100 domains.
Cheers Edgar
Edgar J. Kaiser
www.emphys.com
Peter, you will not get around studying the application builder. I guess you will have to look into the definition of selections and component couplings. Make yourself familiar with the method-recording function. It allows to record all the clicking (and the API calls behind) you do to manually define the functionality you need. Then you can wrap that into some kind of loop to automate things for 100 domains. Cheers Edgar
Walter Frei COMSOL Employee
Posted: 6 years ago 2018年9月26日 GMT-4 10:29
Hello Peter, You may also find the techniques here useful: https://www.comsol.com/blogs/how-to-postprocess-fields-over-arbitrary-geometries/ Note also the sample file linked at the bottom.
