                                2011年8月18日 GMT+8 13:57
draw lines close to the values you want with a mouse, then edit the numerical values the the final desired ones.
if its a right angle, draw a box, add the diagonal, then split the curve and keep only the three desired, combine the lines into a "solid"
                                2013年8月6日 GMT+8 01:01
                                                    I think the easy way is to select to draw a Polygen but you can set three point out of the five to sit on eachother, this way it will become a triangle.
Regards
Yashar
Regards
Yashar
                                2013年8月6日 GMT+8 01:32
                                                    Use polygon feature. Define the x,y or (r,z) coordinates for the 3 points in the right order. Plot. This should work.
                                2013年8月6日 GMT+8 01:38
                                                    Sorry. i work on 4.3.
