2D flow solution plots
I had posted a couple of days ago about modeling a microfluidic channel with 2D flow through it.
The channel is created in a plastic cube and the cube is bonded on to a thin glass plate.
The plate is heated from below by a metallic strip and I would like to see the temperature profile across the fluid
(first stationary, then time dependent).
No matter what boundary conditions I impose, I get an error saying no solution could be found and I see that the plots are unrealistic.
I have checked the geometry and the material properties and they are okay.
How can I couple the heat flow from the source with the fluid flow?
Can you suggest any other corrections?
5 Replies Last Post 2011年9月13日 GMT-4 10:40
Lechoslaw Krolikowski
Posted: 1 decade ago 2011年9月9日 GMT-4 07:13
To couple the heat transfer with the fluid flow use Non-Isothermal Flow or Conjugate Heat Transfer.
Hi, To couple the heat transfer with the fluid flow use Non-Isothermal Flow or Conjugate Heat Transfer.
Posted: 1 decade ago 2011年9月9日 GMT-4 17:14
Hey,
Thanks for your reply.
I tried using conjugate heat transfer but I still cannot get a solution. Not even for a stationary setup.
I tried it for a simple flow across a horizontal channel with an inlet flow rate.
Strictly speaking, I do not need a condition at the outlet but I tried it with an outlet velocity as well.
Is there something I am missing in the settings?
Hey, Thanks for your reply. I tried using conjugate heat transfer but I still cannot get a solution. Not even for a stationary setup. I tried it for a simple flow across a horizontal channel with an inlet flow rate. Strictly speaking, I do not need a condition at the outlet but I tried it with an outlet velocity as well. Is there something I am missing in the settings?
Posted: 1 decade ago 2011年9月10日 GMT-4 06:04
It is difficult to say without insight into your *.mph file.
Hi, [QUOTE] Is there something I am missing in the settings? [/QUOTE] It is difficult to say without insight into your *.mph file.
Posted: 1 decade ago 2011年9月12日 GMT-4 17:32
I have attached the mph file for the model.
Could you take a look at it and tell me what I am missing?
Thanks.
Hi, I have attached the mph file for the model. Could you take a look at it and tell me what I am missing? Thanks.
Posted: 1 decade ago 2011年9月13日 GMT-4 10:40
I've reviewed your model1.mph file. I have the following comments and advice.
* Conjugate Heat Transfer node *
- Inlet subnode. The flow rate 0.0001m3/s is unrealistically high.
- Outlet subnode. Boundary condition: Instead of Laminar outflow select Pressure then set, say, 1atm.
- Add the Temperature subnode. Select boundary 6. Set the temperature of the inflowing water (say 293K).
- Add the Outflow subnode. Select boundary 18.
* Mesh node *
Apply denser mesh. Try Extremly fine instead of Fine.
I hope that this will help you.
Andrzej
Hi, I've reviewed your model1.mph file. I have the following comments and advice. * Conjugate Heat Transfer node * - Inlet subnode. The flow rate 0.0001m3/s is unrealistically high. - Outlet subnode. Boundary condition: Instead of Laminar outflow select Pressure then set, say, 1atm. - Add the Temperature subnode. Select boundary 6. Set the temperature of the inflowing water (say 293K). - Add the Outflow subnode. Select boundary 18. * Mesh node * Apply denser mesh. Try Extremly fine instead of Fine. I hope that this will help you. Best regards, Andrzej
