Comsol Import interactive plots
Dear Users,
I am linking Matlab and Comsol and I obtain my 2D plots in Matlab using the well known command: model='mymodel' mphplot(model, 'pg1');
The problem is that i am running the simulation again from Matlab, and then the plot does not change. I always obtain the same plot even when I run the simulation again in Comsol from Matlab.
Any advice or help will be appreciate it. Thanks,
Joaquin Faneca
1 Reply Last Post 2019年2月18日 GMT+8 21:28
Posted: 6 years ago 2019年2月18日 GMT+8 21:28
This sounds strange. Are you sure that you are changing something in the model before solving that affects the result?
You can use the command mphlaunch to open Comsol Desktop so you can view the model settings and results there as well to compare.
Lars Gregersen
Comsol Denmark
This sounds strange. Are you sure that you are changing something in the model before solving that affects the result? You can use the command mphlaunch to open Comsol Desktop so you can view the model settings and results there as well to compare.
