Edgar J. Kaiser
Certified Consultant
6 years ago
2019年3月12日 GMT+8 18:44
Sujoy,
for the dynamic analysis all domains need to have a small electrical conductivity in mf, say 1 S/m. Maybe it can be even lower, you need to try.
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Sujoy,
Edgar
6 years ago
2019年3月13日 GMT+8 19:46
Hello Edger,
I have tried with small conductivity but still not running the simulation. Could you please take a look to my simulation file which is attached ?
Thanking you
Sincerely
Sujoy
Hello Edger,
Thanking you
Sincerely
Sujoy
Edgar J. Kaiser
6 years ago
2019年3月13日 GMT+8 19:51
I did test it. I applied 1 S/m to air and to the piezoelectric domain and it solved.
Edgar J. Kaiser
www.emphys.com
6 years ago
2019年3月14日 GMT+8 14:02
Hello Edger,
Now it works. Its a great help for me. I am absolutly thankful to you. Though, simulation is taken much more time. Is there any way to redue it?
Looking forward for your kind reply.
Thanking you
Sujoy
Hello Edger,
Thanking you
Sujoy
Edgar J. Kaiser
6 years ago
2019年3月14日 GMT+8 17:36
Updated:
6 years ago
There may be a couple of ways:
* Reduce the size of the model
Find out if the mesh can be coarser
Use lower order discretization
Try different direct and iterative solvers
Optimization can be tedious.
Edgar J. Kaiser
www.emphys.com
* Find out if the mesh can be coarser
* Use lower order discretization
* Try different direct and iterative solvers
6 years ago
2019年3月14日 GMT+8 18:00
Thanks a lot Edger.
6 years ago
2019年4月3日 GMT+8 21:24
Hello Edgar,
Hope everything is going well. Currently, I am facing a problem regarding the aforementioned problem. Though, it was solved for lower frequency region but when I am trying to solve with higher frequency region such as, 10 kHz, it is not solving and returned the following massages:
Maximum number of segregated iterations reached.
Returned solution is not converged.
Not all parameter steps returned.
Could you please help me in this regard?
Thanking you
Sincerely
Sujoy
Hello Edgar,
Thanking you
Sincerely
Sujoy
6 years ago
2019年5月20日 GMT+8 19:53
Hello Sujoy,
Have you been able to sort out the above problem of not being able to simulate in higher frequency range...??
Hello Sujoy,
6 years ago
2019年5月20日 GMT+8 20:03
Hello Sir/Madam,
No, till now it is not solved.
Hello Sir/Madam,
