problem with time dependent phase transition model
Posted 2011年10月23日 GMT+8 19:06 Heat Transfer & Phase Change Version 4.0a 2 Replies
Hi all,
I've built a model which involves a phase transition.
I want to see how long does it take for the phase transition to occur.
when I run the model with range(0,2,800) it gives logical results
with the typical graph of temperature vs. time where the temperature stays the same
as long as the phase transition occurs. But, when I run with (0,2,900), the phase
transition disappears and I get a graph with a continues temperature rise.
Is there anyone who encountered the same problem or has a solution?
thank you,
Zvika
thank you,
Zvika
2 Replies Last Post 2013年9月11日 GMT+8 01:19
