simulation electric field distribution of high voltage on a rotating machine with high voltage supply
Posted 2019年7月11日 GMT-4 01:56 Electromagnetics, Low-Frequency Electromagnetics, Structural & Acoustics Version 5.3a 0 Replies
Hi, Currently, I have project in build a machine consists of motor , high voltage supply and metal syringe. The process of machine is metal syringe will be attached to the motor using insulator coupling and high voltage will be connected to the needle syringe. the schematic diagram as an attached file. The problem I had is when motor is rotate and positive high voltage supply connected the metal syringe while negative to the aluminium plate during the process, motor and high voltage will stop.
I already done simulation electric field potential high voltage supply but without motor.
My question is
- How to do simulation on high voltage electrostatic breakdown voltage?
- How should I input the rotating motor to the simulation?
- Is it using rotating machine 3D tutorial application?
Hello Norul Norzain
