6 years ago
2019年7月22日 GMT-4 08:56
Updated:
6 years ago
2019年7月22日 GMT-4 08:46
It would be better if you posted your file. You may get a better response.
6 years ago
2019年7月23日 GMT-4 08:26
Updated:
6 years ago
2019年7月23日 GMT-4 08:24
Sorry, I send the file with cleaned results to reduce the file size. My goal is to study the model in frequency domain. Thank you for helping me
6 years ago
2019年7月23日 GMT-4 09:38
Updated:
6 years ago
2019年7月23日 GMT-4 09:28
Just looking at it very briefly, on the coil domain setting did you intend for this to be a bundle of wires or single wire wound around a core? Homogenized multiturn is for tiny wire bundles. If that wass your intent then ok. Here is a good example to check out related to this:
https://www.comsol.com/model/multi-turn-coil-winding-around-a-ferromagnet-23641
I would also suggest that you disable the circuit option for now. You can solve this problem without it but activate it later when it model otherwise works. I find it easier to add complexity after the problem solves successfully. That way if something goes wrong you have a better chance of fixing it.
There are other example files to look at on the comsol website. I cannot spend a lot of time on this problem but maybe somebody else can help with more detail.
6 years ago
2019年7月23日 GMT-4 12:55
Updated:
6 years ago
2019年7月23日 GMT-4 12:51
Thanks a lot for the help, yes I want to model a single wire around the ferromagnetic core.
I think that the problem is caused by the geometry of the coils, so I did a second model using a toroidal geometry for the coils, now the resistance is quite smaller. Thank you again
