2011年11月22日 GMT-5 01:24
you have at least two ways:
1) you use a transient time dependent solver and write out the voltage or any excitation dependency as
V0*sin(2*pi*frew*t)
then wait quite some time to see the solver resolve this with a time stepping of at least 5*freq per second
2) you use the harmonic solver, based on a harmonic development of the physic equations. You define the excitation amplitude V0 and get out the amplitude or rms (pls check carefully the doc and the equations for the variable you are using) at a given frequency, in one solver step
V0*sin(2*pi*frew*t)
2011年11月22日 GMT-5 07:05
Hi Ivar,
I tried the first suggested way and I think it worked. Thank you
Hi Ivar,
8 years ago
2016年7月28日 GMT-4 18:14
V0*sin(2*pi*frew*t)
Hi Ivar,
I am not sure that I completely understand the first method. So in component variables I set V0 to be 200 [V] and frew to be 36000 [Hz]. I copied and pasted the equation into the voltage in the electric potential BC in electrostatics and I have a time dependent solver set up (is that the same as transient?). So my time step should be 180000 [s] because that is 5 times my frequency?
Thank you,
[QUOTE]
V0*sin(2*pi*frew*t)
[/QUOTE]
Hi Ivar,
Thank you,
