interpolation function alternative
Posted 2011年11月24日 GMT+8 08:27 Geometry, Materials Version 4.2, Version 4.2a 0 Replies
I tried to create different material (where each material corresponds to each block), but comsol after a few materials, just freezes.
In one initial approach, I can define an interpolation function with x,y,z coordinates and conductivity values, imported from a txt file.
If I use the coordinates of the center of each block, then I don't get to assign a uniform value to the whole block.
If I try with giving coordinates of the nodes of each block, then I have duplicate points.
I can try not to give the exact node coordinates, but just slightly small, so I can avoid the duplication. This approach makes the interpolation function, computational heavy.
Is any other approach I could use?
Hello Marios Karaoulis
