6 years ago
2019年11月14日 GMT+8 06:06
Updated:
6 years ago
2019年11月14日 GMT+8 01:06
- If you want to calculate impedance you should be doing a frequency dependent (sinusoidal steady state) study.
- In many modules you can assign a Terminal boundary condition and the terminal impedance is available as a global variable.
- There was no model attached. Be sure to remove the solutions before posting.
1. If you want to calculate impedance you should be doing a frequency dependent (sinusoidal steady state) study.
2. In many modules you can assign a Terminal boundary condition and the terminal impedance is available as a global variable.
3. There was no model attached. Be sure to remove the solutions before posting.
6 years ago
2019年11月14日 GMT+8 18:05
Updated:
6 years ago
2019年11月14日 GMT+8 18:07
Hi Dave,
Thank you for reply. Sorry, it was my mistake. The model was attached.
Would it be possible to look at the model?
I have defined bipasic stimulus pulse and applied a boundary.
Kind regards,
Enver
Hi Dave,
Kind regards,
Enver
6 years ago
2019年11月14日 GMT+8 23:16
Updated:
6 years ago
2019年11月14日 GMT+8 18:16
See #1. You can only calculate an impedance for sinusoidal excitation. Impedance is only defined for sinusoidal steady state excitation.
6 years ago
2019年11月18日 GMT+8 18:40
Hi Dave,
Thank you for your comment.
I have to apply bihasic rectangular signal as an input. Do you mean I can not calculate impedance if I apply any types of signals wavefrom but sinusoidal?
Kind regards,
Enver
Hi Dave,
Kind regards,
Enver
6 years ago
2019年11月19日 GMT+8 04:24
Updated:
6 years ago
2019年11月18日 GMT+8 23:24
Hi Dave,
Kind regards,
Enver
That is exactly what I am saying. Impedance is defined as the ratio of the (complex) voltage phasor to the (complex) current phasor. Phasors represent a sinusoidal signal that has been applied for a very long time.
>Hi Dave,
>Kind regards,
>Enver
6 years ago
2019年12月9日 GMT+8 19:36
Updated:
6 years ago
2019年12月9日 GMT+8 19:37
Hi Dave,
Thank you for your suggestions. Do I need to just apply preiodic sinusoidal signal to a boundary then calculate impedance variation (I belive I can do terminal voltage/terminal current ) or do I need to define an equation for the impedance variation?
If it is possible, can you please guide me on my model?
Kind regards,
Enver
Hi Dave,
Thank you for your suggestions. Do I need to just apply preiodic sinusoidal signal to a boundary then calculate impedance variation (**I belive I can do terminal voltage/terminal current** ) or do I need to define an equation for the impedance variation?
Kind regards,
Enver
