2011年12月7日 GMT-5 09:35
Birgit,
I think your expression must be sr_maxi*(sr_maxi>0)
This will plot all values > 0 and will plot 0 for negative values.
Maybe just defining a range for the plot would yield the same result?
Cheers
Edgar
Birgit,
Cheers
Edgar
2011年12月8日 GMT-5 02:37
Dear Edgar,
thanks for your reply.
Using the expression the square stresses [Pa^2] was shown, not what I wanted. But as usual, the simple things work best - just adjusting the range to 0-70 MPa gave me the needed picture. Thanks for the hint - I sometimes tend to think too complicated ;-)
Greetings, Birgit
Dear Edgar,
Greetings, Birgit
2011年12月9日 GMT-5 01:08
What about trying sr_maxi*(sr_maxi[1/Pa]>0) that should remove the extra Pa unit, and Boolean's work best dimension-less
2011年12月12日 GMT-5 10:41
Dear Ivar,
thanks also for your reply - I just tried your option and it worked - the stress is shown in MPa. Although the edition of the range has the advantage that everything below 0 is left blank and only stresses above 0 MPa is colored, whereas your suggestion already displays 0 MPa in dark blue. The option with everything blank besides >0 MPa is a bit clearer for looking at the overview.
Birgit
Dear Ivar,
Birgit
2011年12月12日 GMT-5 10:47
Hi Ivar,
I find it a little funny (or isn't it strange?) that a boolean expression returns a unit? I am wondering if this is consistent from mathematical point of view.
Cheers
Edgar
Hi Ivar,
Cheers
Edgar
2011年12月12日 GMT-5 16:08
Hi Edgar
I do agree with you, but that is the only explanation I can come to if there is a ^2 on the units, or there are something more on the line not shown. I havent rechecked, I mostly make my variables without units to enter a boolean expression, but in some fields its not possible, it flags an error, it seemsthat units are not accepted systematically and everywhere. Anyhoe I do not have 3.5 running anymore so I cannot check either ;)
Hi Edgar
