post processing of result
sir,
i want to retrieve co ordinates of the nodes which have values of field variable (at a specified time) above a certain limit from the results. are there any built in function for that or should use probes to evaluate or can i use matlab and write program to retrieve data. which is best and easy way.
please help
1 Reply Last Post 2011年12月21日 GMT-5 04:44
Posted: 1 decade ago 2011年12月21日 GMT-5 04:44
I'm sure Matlab or the Api I/F will do the job nicely, but I'm not sure you can get the coordinates in the GUI, however you can plot the region with the "filter" sub-node
Hi I'm sure Matlab or the Api I/F will do the job nicely, but I'm not sure you can get the coordinates in the GUI, however you can plot the region with the "filter" sub-node -- Good luck Ivar
