Stator field does not move in simulation
Hi Friends,
I am trying to simulate a linear motor segment with periodic boundary condition and sweeping the position of rotor with parameter sweep. However my stator field does not move, can anyone help me to solve this?
I am attaching the model. I am using 4.2a Magnetic field with ale.
Arijit
2 Replies Last Post 2012年1月3日 GMT+8 00:50
Posted: 1 decade ago 2012年1月2日 GMT+8 18:32
Hi!
I think, the identity pair should better be "continuity" instead of "periodic condition".
But the periodic condition at the left and right side is still a bit strange...
Ralf
Hi! I think, the identity pair should better be "continuity" instead of "periodic condition". But the periodic condition at the left and right side is still a bit strange... Ralf
Posted: 1 decade ago 2012年1月3日 GMT+8 00:50
Hi Ralph,
Thanks for your mail. Yes you are right still this has some problem. What I was feeling the continuity should have been between only the non-intersecting section of the common boundary (when it seperates out). However I could not enforce any boundary condition in that way.
Let me know if you have some other idea I can try.
Once again I appreciate your help.
Arijit
Hi Ralph, Thanks for your mail. Yes you are right still this has some problem. What I was feeling the continuity should have been between only the non-intersecting section of the common boundary (when it seperates out). However I could not enforce any boundary condition in that way. Let me know if you have some other idea I can try. Once again I appreciate your help. Thanks Arijit
