electric field along a line
I'm hoping someone can advice me on this problem.
I've recently been using Comsol 4.2, after using another in-house 3D FEA package for quite sometime.
but one thing I've been able to do before, was plot the electric field across a line.
so for e.g, I was able to plot the electric field (graph) on the surface of a conductor/insulator or any other object, in a straight line, given the co-ordinates.
At the moment, struggling with the this, in Comsol
I am not sure if i'm looking in the right place, but I still haven't managed to find a command that allows me to specify a line across which I can find the electric field. I can draw a patch, but this does not show me the exact value at a certain location. An electric field line, will allow me to see the actual values of the field.
Any advise??
Thanks in advance
1 Reply Last Post 2012年1月6日 GMT+8 03:51
Posted: 1 decade ago 2012年1月6日 GMT+8 03:51
You can either plot a variable as defined by the coordiantes of a domain, a bondary, an edge or a point (at least 3 of these, it depends if you are in 2D or 3D). But then these entities must be defined by the geoemtry.
However, you can always also define your own cut plane, line ... where the variable is to be defined by interpolation from the appropriate Result Data Set (try a right click on the Data Set node) and then you can attach a plot to this new "data set" node
Hi You can either plot a variable as defined by the coordiantes of a domain, a bondary, an edge or a point (at least 3 of these, it depends if you are in 2D or 3D). But then these entities must be defined by the geoemtry. However, you can always also define your own cut plane, line ... where the variable is to be defined by interpolation from the appropriate Result Data Set (try a right click on the Data Set node) and then you can attach a plot to this new "data set" node -- Good luck Ivar
