How to select multiple boundries?
Hi:
I have constructed the metasurface geometry with matlab script. Now I'm trying to creat mesh, but as in the picture, there are way too many surface to select manually, and it seems that the number of every surface is not sequencial. So, How can I select all top surface of every pillar at once?
Thank you! Chang Chang
2 Replies Last Post 2020年3月20日 GMT-4 05:53
Posted: 4 years ago 2020年3月18日 GMT-4 08:22
Hello Chang,
There are several tools in the GUI to create selections without picking entities one by one. They are accessed through the Model Builder under the Component > Definitions > Selections . One of them will select entities in a cylinder; that should work for your case. Note that you can also perform boolean operations on selections, etc, see Chapter 6 in the Reference Manual (Accessible through File > Help > Documentation, as always).
Jeff Hiller
Hello Chang, There are several tools in the GUI to create selections without picking entities one by one. They are accessed through the Model Builder under the Component > Definitions > Selections . One of them will select entities in a cylinder; that should work for your case. Note that you can also perform boolean operations on selections, etc, see Chapter 6 in the Reference Manual (Accessible through File > Help > Documentation, as always). Best regards, Jeff
Posted: 4 years ago 2020年3月20日 GMT-4 05:53
Thank you, Jeff. That helped a lot.
