U-shaped Plate (Heating & Magnetic Fields)
Posted 2012年1月22日 GMT+8 18:02 Mesh Version 4.2a 5 Replies
Greetings!
As you can see in the uploaded file, I'm trying to simulate the heating and the magnetic field of an array of U-shaped plates. Each plate has an independent current source.
So my problem is that I have an idea of what I want to do but I can't implement this in Comsol. I've already gone through the AC/DC Module-Tutorial and I watched the Heat-Transfer Video-Tutorial (the Fuse).
So as you can see in the file I uploaded, I used the "Electric Current" Module and the "Heat Transfer in Solids" Module (as I've seen in the Fuse-Tutorial). The magnetic field simulation is not that important so my focus is on solving the heat problem.
I can't get any results with the settings I use at the moment. The solver ran for about 2 hours (1600 Iterations on the GMRES solver) before I stopped it. So I guess there are some problems with the settings in either the "Electric Currents" or the "Heat Transfer in Solids".
Secondary question to the AC/DC Module:
In the AC/DC Module Tutorial you build a hollow sphere around the model. May I ask why? I guess to simulate an open space but I don't really know how to implement this in my problem because I really don't know what boundaries to select for that purpose.
5 Replies Last Post 2012年1月24日 GMT+8 05:19
