2012年2月1日 GMT-5 15:31
I'm not sure aI catch you 100% for that question, but basically when I want to analyse my data I add internal boundaries, as these are easier to pick and to integrate over.
But the data set cut line, edge, surface ... allows you too to define a subset of your full results and COMSOL interpolates the values to map over the defined cut line, plane ...
So both should work and give similar results.
Now what I do notflly catch is the STD of a variable over a cut line or plane, I'm missing sme independent variale, or is it the time value.
What you can do is to define a cut plane, integrate over the plane, eiter full plane or over several sub aprture, i.e. to get a flow local velocity, versus time and dump that into a table (vis dependent variables). Then you can add a RMS or STD from thereon the list, column by column (check the table operations)
2012年2月5日 GMT-5 18:35
Hi Ivar,
I need to have several cut planes at different depths in my very narrow pipe but i am trying to define the plane with 3 points but the plane generated is not the one i am after but it is the bigger cylinder surrounding my narrow pipe.it is like i have generated it via quick option.
would you please let me know what i can do for that?
thanks
Hi Ivar,
thanks
