Robert Koslover
Certified Consultant
5 years ago
2020年5月23日 GMT-4 23:41
That seems reasonable to me, although I don't do problems like that very often, so take my advice with a grain of salt. Anyway, if you want to be sure, simply do several runs with different size domains and compare! Mesh (how fine or coarse) and choice of element order (linear, quadratic, etc.) may make a difference too. In part, your choices will come down to how much inaccuracy you are willing to tolerate, how fast your computer is, how much memory you have, etc. (By the way, I presume the wavelength you are referring to is in the water, not the wavelength in free space.) Finally, if everything is nicely spherical, isn't it possible that this might be an already analytically-solved problem, and so you can (more or less) look up the answer in the literature? Or are you, perhaps, trying to validate the code?
That seems reasonable to me, although I don't do problems like that very often, so take my advice with a grain of salt. Anyway, if you want to be sure, simply do several runs with different size domains and compare! Mesh (how fine or coarse) and choice of element order (linear, quadratic, etc.) may make a difference too. In part, your choices will come down to how much inaccuracy you are willing to tolerate, how fast your computer is, how much memory you have, etc. (By the way, I presume the wavelength you are referring to is *in the water*, not the wavelength in free space.) Finally, if everything is nicely spherical, isn't it possible that this might be an already analytically-solved problem, and so you can (more or less) look up the answer in the literature? Or are you, perhaps, trying to validate the code?
