Using results or a previous simulation as initial condition and change loads.
Posted 2012年2月13日 GMT-5 05:21 Studies & Solvers, Structural Mechanics Version 4.2 4 Replies
I am running several static structural simulations of PET fixed-fixed beam and pre-compressed at its ends.
First of all, I have solved the initial pre-compression at the first step.
Then, I want to use the results of this analysis I have saved, to run several static stepped simulations (in the same way as www.comsol.com/community/forums/general/thread/25586/ ) in which I have to change the conditions (I have to add a prescribed displacement from the resulting point of the previous analysis).
How can I use the solution of the previous solution as initial values? How can I change the conditions, taking into account the previous solution?
Thank you in advance.
Kind Regards.
Gaetano
Kind Regards.
Gaetano
4 Replies Last Post 2012年2月27日 GMT-5 11:23
