Debugging mesh import
Posted 2020年6月24日 GMT+8 00:39 Mesh Version 5.5 0 Replies
Hi all,
In a previous post I asked about topological issues, and that was solved. So I began working on an exporter from a mesher I developed to mphtxt.
However, I am finding problems in moving from a simple tetrahedron, to a prism, but I don't find any log (even in the debug log window). The only output I see is
A problem occurred when building mesh feature 'Import 1'. Error reading file. - Line number: 42
The weird part is that line 42 is a comment line. Moreover, it is a simple copy/paste from the tetrahedron that COMSOL imports without problems.
How can I debug this issue? I am attaching the two files and pasting down here.
Thanks for any pointers! Franco
Here's the tetrahedron that works:
# Major & minor version (For the current version, supported by COMSOL Multiphysics version 5.5, the first two entries in a file are 0 1)
0 1
# Number of tags (The tags are strings that function as identifiers so that objects can refer to each other)
1
# Tags (The number preceding the tag name is the number of characters in the string)
6 mesh23
# Number of types (In the current version, 0 1, of the COMSOL native data format, types are not used and are ignored.)
1
# Types
7 ignored
# --------- Object 0 ----------
# Mandatory header
0 0 1
# Object type (String that defines which type of object follows)
4 Mesh
# Version of internal COMSOL class
4
# Space dimension
3
# Number of mesh vertices
4
# Lowest mesh vertex index
0
# Mesh vertex coordinates (x, y, z)
0 0 0
1 0 0
0 1 0
0 0 1
# Number of element types (0-based indexing)
1
# Element type #0
# Type name (The number preceding the tag name is the number of characters in the string)
3 tet
# Number of vertices per element
4
# Number of elements
1
# Elements
0 1 2 3
# Number of geometric entity indices (domains?)
1
# Geometric entity indices
1
The prism does not work:
0 1
1
6 mesh23
1
# Types
7 ignored
# Mandatory header
0 0 1
4 Mesh
4
# Space dimension
3
12
0
0 0 0
1 0 0
0 1 0
0 0 1
1 0 1
0 1 1
1
# Element type #0
3 tet
# Number of vertices per element <------- THIS IS LINE 42
4
3
# Elements
0 1 2 3
2 3 1 4
4 3 5 2
1
# Geometric entity indices (each element belongs to domain number?)
1
1
1
Hello Franco Milicchio
