                                2012年2月24日 GMT+8 04:03
boundary layers are interesting along all boundaries across which you have strong gradients, particularly for diffusion type equations. Even in laminar flo, along a no-slip boundary you have a rather strong gradient of the velocity, ending at U=0 on the boundary. Therefore COMSOl always proposesby defult boundary layers, for the CFD on such no-slip (and perhaps many others haven checked all cases) boundaries. And this also in laminar flow.
Personally I use boundary layers also in HT transient analysis between material with very different heat diffusiviies, or along boundaries with constant T, where I have a very different initial condition in the material (again essentially for transient solver cases, far less critical for steady state solving))
                                2012年10月10日 GMT+8 17:57
                                                    Does anyone have any suggestions for joining a boundary layer mesh to a regular tetrahedral mesh. I have an acoustics model which contains a narrow pipe where the thermoacoustics model is implemented but is mostly free space. The boundary mesh seems sensible for modelling the interaction of fluid with a boundary layer but it won't mesh with the remaining space.
Alasdair
Alasdair
                                2012年10月10日 GMT+8 19:36
Often a boundary layer goes all the way out to the outer edge of your model (to the in-out-lets), if you need to continue the mesh from there for another physics, you might get around by using a mesh "convert" (to tri) on the in-out-let boundaries, or you might use assembly mode but that is rahter heavy to define all the pairs
