How to keep each solution when using multiple solvers
I’m running a model that uses 5 Time-Dependant Solvers.
If I compute all solvers, the resulting solution will show the last solver data only.
However, I need to get data from each solver.
Actually I’m doing it manually by computing iteratively each solver… quite long.
Is there an option to keep every solver solution as a unique solution?
2 Replies Last Post 2012年2月28日 GMT-5 11:19
Posted: 1 decade ago 2012年2月28日 GMT-5 01:16
you can add a STORE SOlution node in the sulver sub-nodes, if COMSOL has not added those by default. then you will have 5 data sets, if you set them up correctly. Only thing be sure your initial conditions are correct, either linked or separate, as COMSOl might try to link them by default, which might not be what you want ;)
Hi you can add a STORE SOlution node in the sulver sub-nodes, if COMSOL has not added those by default. then you will have 5 data sets, if you set them up correctly. Only thing be sure your initial conditions are correct, either linked or separate, as COMSOl might try to link them by default, which might not be what you want ;) -- Good luck Ivar
Posted: 1 decade ago 2012年2月28日 GMT-5 11:19
Ivar,
it works !
Thank you.
Ivar, it works ! Thank you.
