Import and assign grain orientation from an .csv file
Posted 2020年7月14日 GMT-4 09:57 Corrosion Processes, Corrosion & Corrosion Protection, CAD Import & LiveLink™ Products for CAD Version 5.4 0 Replies
Hi you all, I am trying to investigate the impact of grain orientation on the steel corrosion at the moment. I have used external software: MTEX, Gmsh and Matlab to generate mesh (.msh) and extract a properties file (.csv), which contains the grain orientation data, from an EBSD figure . I converted the mesh file to readable data for Comsol and imported the meshed object into Comsol successfully then construct solid geometry from the imported mesh. Now I am trying to import .csv file to Comsol in order to assign the grain orientation to the constructed geometry. Unfortunately, so far I could not find any procedure to do this. I tried to import data and implement interpolation function in Comsol but the final shape had uneven surface and does not look like what I expected. (as it is indicated in the attached .png file). I am writing to kindly ask you for some suggestion to make it. In the attachment you can find my importable .mphtxt, .csv and .png files. Thank you very much in advance!
Hello Vahid Jamebozorgi
