Doesn't COMSOL accept complex interpolation functions?
It seems so...
I have to define the real and imaginary parts separately.
4 Replies Last Post 2012年3月3日 GMT-5 06:39
Posted: 1 decade ago 2012年3月2日 GMT-5 17:49
I did so by writing like this:
real(f)
imag(f)
where f is the desired function. For example, in my work, I wanted to plot a function which was frequency- dependant. But, I just needed to plot the real part. So I defined it as above in Global Expressions and plotted it easily!
I did so by writing like this: real(f) imag(f) where f is the desired function. For example, in my work, I wanted to plot a function which was frequency- dependant. But, I just needed to plot the real part. So I defined it as above in Global Expressions and plotted it easily!
Posted: 1 decade ago 2012年3月2日 GMT-5 17:52
Thanks for ur reply!
But I don't get ur point... I mean define a function from complex data.
Thanks for ur reply! But I don't get ur point... I mean define a function from complex data.
Posted: 1 decade ago 2012年3月3日 GMT-5 05:03
you can always enter the ral and complex part separately and combine tem in the equations or with an anlytical function (do not forget to turn on the "can produce Complex data from real arguments)
Test it out with a simple eample to be 100% convinced ;)
I believe it worked also like that in 3.5
Hi you can always enter the ral and complex part separately and combine tem in the equations or with an anlytical function (do not forget to turn on the "can produce Complex data from real arguments) Test it out with a simple eample to be 100% convinced ;) I believe it worked also like that in 3.5 -- Good luck Ivar
Posted: 1 decade ago 2012年3月3日 GMT-5 06:39
Thanks, Ivar!
I think this is the way to get around the problem.
Thanks, Ivar! I think this is the way to get around the problem.
