2012年3月4日 GMT-5 10:12
Just found out that parametric sweep that alters a mesh or geometry parameter has to be a batch-node sweep, a solver-sweep won't work.
2012年3月4日 GMT-5 17:34
In the GUI you need to add tha Parametric Sweep node before the solver node to get around the geoemtry and/or mesh. The solver swep (continuation) does NOT loop around the geoemtry nor mesh.
Another difference: the contination sweep uses the initial condition of sweep "n" to start sweep "n+1", while the parametric swep start from orignal initial conditions for EACH step
2012年3月5日 GMT-5 07:24
Hi, thank you for the explaination.
There is something mentioned in the 'LiveLink for Matlab UserGuide' (chapter 'Running the Model in a Loop'):
'To automatically vary the value of geometry settings or to combine a parametric analysis with a time-dependent or eigenfrequency study, create a batch node that contains a parametric feature.'
Then they are using a batch node and two solution sets for the sweep. In my code I did it like this and it seems to work. Is that eqal to your approach in the GUI?
2012年3月5日 GMT-5 14:42
Probably, but I do not have more knowledge than you to tell that exactly, and since V4 I hardly use matlab, so there are many things in the new inerface that I have not tested out
