How to simulate Heat drives the flow of groundwater
Posted 2020年8月13日 GMT+8 22:53 Fluid & Heat, Heat Transfer, Porous Media Flow 0 Replies
Hi there, I hope to simulate heat drives the groundwater flow. can I use the Darcy's Law and Heat transfer in porous media ? Imagine a porous medium filled with water, where the pressure is distributed according to the hydrostatic pressure. After the bottom is heated, the pore water will flow under the thermal drive. When the temperature is high enough, will phase change occur? which interface should I use? How to simulate? Thanks a lot~~
Hello 礼恒 王
